HEC-RAS- I downloaded stream survey
PT60056
6
HEC-RAS- I downloaded stream survey data using .csv file with north, east and elevation format.
The stream flows from north to south but HEC-RAS schematic shows stream flowing from south to north. What is the reason for this and how do I fix it?
Also, is there another way to add stream cross section data such that it shows up in a straight line so that it is easy to merge with another model which is imported from HEC-2?
 https://files.engineering.com/getfile.aspx?folder=0f1f74e1-14f1-4715-929f-58a2d07e0c73&file=HEC-RAS_schematic.JPG
