change the centre line of bridge in AASHTOWare BrR
saurav.str
12
Is there a way to change the HCL or Center Line of the Bridge in AASHTOWare BrR? The only skewed abutment is the first one in my bridge and BrR assumes the centerline as HCL. I could not find a way to change that as my Reference line or HCL is a bit below the actual centerline.
Thank you.
 https://files.engineering.com/getfile.aspx?folder=82b8dd10-2780-4e0b-812b-443c4dedd4db&file=Untitled.png
Reference line is set in the typical section. However I’m not sure how this really fixes your skew issue. You are able to do independent skews on the abutments regardless you just have to make sure your member lengths match up. The support staff is very helpful but the program is loaded with bugs.
