Notch Effect
lLouie
Student
Jun 19, 2024
69
I want to perform fatigue analysis to see the notch effect. I drew a notch on a metal part I did the static analysis, but there is much stress due to the singularity. How can I prevent this?
I will do the fatigue analysis in nCode.
I don't really understand the question or issue. A notch will cause a stress concentration. You can't just "prevent it".
run non-linear FEA
If you have a sharp notch (with a point) ... add a finite radius.
Thank you so much your replies. Yes, I know that the notch will cause a stress concentration, but when I want to do fatigue analysis, I see the 'static failure' in the result. Maybe the stress is so high. Actually, I want to see that if there is a notch after the production,how much does its life change? How do you do notch effect fatigue analysis for a metal part? Not for specimen.
I will try to use the finite radius
you are using FEA (linear elastic material) incorrectly ... or rather extracting invalid information from the model. Any stress above yield is invalid (for a linear elastic material). You may be able to use this with a "Neuber" notch analysis ... but I haven't.
So one fix is to use non-linear material (elasto-plastic).
Also, I surmise, your notch has a sharp (point) radius, which is easy to model but impractical.
Also where you are trying to get the stress at the base of a Kt, you need a lot of mesh refinement to have any chance of a real value.
But I won't trust any model result for this.
Normally in fatigue analysis, we use gross section stress (which we might get from FEA), and the Kt of the notch is applied separately, and then some analysis with S/N diagrams and some spectrum of loads.
If you want to do fatigue analysis, there are plenty of texts out there. Petersen is a good source for Kt, but there are many.
You may want to investigate "ncode" which is an FEA based fatigue analysis.
Thank you so much
I search how I can do it well
