Creo 10 Pro/program Problems
pmbov
Hi fellow Creo Users,
I am currently running Creo 10. I have a situation where I need to create a Pro/program. And for some reason I can not get it to function correctly.
I have gone through many examples on this site and via the google with little luck getting this to function correctly.
I have a 3 part assembly, my first part (BASE) is fixed constrained via X, Y, Z. My second part (screw assy) is fully constrained, and a dimension is given called D33=ball_to_ball. My third part is a “spring” that is flexible by a measurement.
I want to create a pro/program that changes the ball_to_ball with 4 different values.
INPUT
Position1 YES_NO
“Do you want position 1?”
Position2 YES_NO
“Do you want position 2?”
Position3 YES_NO
“Do you want position 3?”
Position4 YES_NO
“Do you want position 4?”
END INPUT
RELATIONS
Position1=10.00
Position2=40.00
Position3=30.00
Position4=60.00
BALL_TO_BALL = POSITION1
IF POSITION1 == NO
ELSE
BALL_TO_BALL = POSITION2
IF POSITION2 == NO
ELSE
BALL_TO_BALL = POSITION3
IF POSITION3 == NO
ELSE
BALL_TO_BALL = POSITION4
IF POSITION4 == NO
ELSE
ENDIF
ENDIF
ENDIF
ENDIF
END RELATIONS
What I am trying to accomplish is the user to pick the known position required to represent the assembly they desire. By answering yes or no to the prompts them to move on to the next position. The positions values are fixed by the design.
Sorry for the long explanation. Any help would be greatly appreciated!
Are you actually using the same variable name for both the yes/no result and the distance?
Also this looks backwards
IF POSITION1 == NO
ELSE
should be
IF POSITION1 == YES
ENDIF
However, the variable names should be
IF POSITION1 == YES
BALL_TO_BALL = DISTANCE1
ENDIF
and so on.
oh darn I did flip them.
Now I am getting errors....
INPUT
POSITION1 YES_NO
!*** ERR: line contains a bad symbol or is otherwise invalid
“DO YOU WANT POSITION1?”
Same for the others
RELATIONS
IF POSITION1 == YES
!*** ERR: Relation has an error.
ELSE
Same for the others
Are my variables wrong?
not sure I understand where you added distance1, was that a new variable?
My end goal is to have the user pick from 1 of the 4 possible options. Similar to:
if the user does not wont position1 then they select no and it moves to the next option position2 and so on. eventfully looping back to position1 again.
If the model already has a parameter called "Position1" and that parameter is already a number, then you cannot reuse it as a boolean (YES_NO) variable.
ProProgram doesn't loop. It won't go back.
Ok thank you for taking the time to reply.
I created another work around. But I do see my mistake.
Thanks for your help!!
Reusing the variable.
Plus I could not get the inputs (YES_NO) to work so I just did number and the did position1 = 1, position2 = 2, etc.
Then used ball_to_Ball with a value for each position.
First I defined the variables Distance_1 (as you said) = #, etc
If position = 1
ball_to_Ball = Distance 1
else
