Specified Minimum Yield Stress for Flexible Pipe.
AnisaMaski
Chemical
Jul 18, 2024
7
Hi everyone.
Im junior engineer and has been assigned to do trawl-pipeline interaction.
My main reference is DNV-RP-F111, and i got stuck how to find plastic moment capacity (mp) which required me to get the value of specified minimum yield stress (SYMS). Since the pipeline is flexible type, I dont have enough data/ source to refer.
Since I have the value for axial stiffness (in tension),(this data usually provided in FEED stage for stiffness of pipeline) i used it to calculate the stress, which stress=Force/cross sectional area, the value will be my basis for the study.
Really appreciate everyone thought/ guidance on this.
Thank you.
You're probably in the wrong forum - I would try the pipelines one and delete this one.
However flexibles work in a different way to rigid steel pipes and so I think you're in danger of using incorrect data.
Flexibles are, well, flexible, and hence tend to move when subjected to force and loads such as trawl boards.
Thank you for the suggestion/ reply. I'm still learning how to use the forum.
I'm also not confident with my method, but need to start somewhere at least.
Have a great day.
