Cam111
- Jul 23, 2024
- 1
I am working to hook up a compressed air tank to a machine to allow for operation in areas where an air line cannot be accessed. The air supply requirements are 0.45 MPa of air supply pressure & a minimum flow capacity of 32 l/min. I am trying to figure out what size tank I would need in order to operate this machine for 4 hours without depleting the tank. I will add that this machine is going to oporate within somewhat quiet environment which eliminates the possibility of an air compressor refilling as used.
