Thermography to survey pipe internal wall loss 3
mariolucas75
70
Dear Forum,
Can anyone share with me the experience or knowledge or advise - is it possible to use thermography imaging to locate potential internal metal loss on piping ?
Different internal surface of piping should have different thermal signature ? What thermography image devise to use ....
There some industrial approaches - but if any of you have any experience ? If I buy for example some flir camera may it work may not it work ?
Thank you
What is the issue with using an ultrasonic device to measure wall thickness?
Given that the thermal conductivity of metal pipe is very high compared to many other materials, I can't see any temperature difference is going to be measurable in terms of temperature difference. You might notice it for a very accurate temp device, but its a new one on me. As bimr says, if you can see the outside, use a U/T probe. Far better and more accurate.
The real issue is how would you calibrate?
How much hotter is too much?
You'd have too many unknowns and like EdStainless suggests, unless you have some specific way to calibrate against a known standard, you're mostly going to be guessing.
Depending on the process fluid and temperature, wall profile radiography might give some useful results.
Not reliably, technically it could work, but the temp change is orders of magnitude lower than background noise levels (think issues like different surface colors, sun vs shade, and a whole host of other factors related to how thermal cameras work). But have seem it done extensively to locate scaled / blocked pipelines, vessels and tanks.
Andrew O'Neill
Specialist Mechanical Engineer
Australia
