Effective inertia of drivetrain with clutch slipping
Alixir420
Student
Aug 5, 2024
1
Effective inertia of drivetrain needs to be calculated. Using equation in Gillespie's book to calculate this. Normal cases with clutch closed are simple. However, how do I incorporate the clutch slipping into this. The engine speed is constant at 3000 rpm when the clutch is slipping. Please help
 https://files.engineering.com/getfile.aspx?folder=d3d539c1-8757-4ced-8d74-613bf1d488b3&file=Question_equation.PNG
You'll have to do it from first principles rather than plugging in numbers to an equation. First you need to decide what you mean by drivetrain inertia and how it can be measured. I'm not sure that the concept is particularly useful as a single number when the clutch is slipping. After all, if the vehicle is stationary the drivetrain inertia is zero, so you need to consider more than just the simple parameters in your equation.
I suspect the desired textbook answer is that if you know the %clutch slip you can modify N to become Nslip=N*(1-clutch slip) where clutch slip is the fraction of slip, from 0 when fully engaged to 1 when fully slipping. I have zero confidence that that is a useful concept.
Cheers
Greg Locock
