Modifying a Part Description without Up-Revving
MarkCA
20
I checked an Inventor 2024 part and drawing into Vault and released it only to then realize I'd forgotten to add a Reference Drawing Number in the AES Model Properties.
Is there some way for me to correct this without creating an entirely new revision?
Mark
If Quick Change is permitted by your administrative settings, that's the solution I'd use. Set your released document revision from Released to Quick Change, make the change, return status to Released.[tt][/tt]
