Catia Vba Part or Product link isolate
FuatErt
Automotive
TR
Hi everyone,
I'm seeking a VBA script capable of efficiently isolating all linked data within a selected CATIA V5 part or product.
Ideally, the script would function as follows:
User interaction: Open the desired part or product.
Script execution: Upon clicking a button, the script would process the selected item and isolate all linked data.
Feedback: A message box would display a confirmation indicating successful isolation, including the part or product name.
Isolating Linked Data in CATIA V5 Using VBA
Hi everyone,
Example:
Sub IsolateLinkedData()
Dim selectedDoc As Document
' Get the selected document (part or product)
Set selectedDoc = CATIA.ActiveDocument
' Code to isolate linked data goes here
MsgBox "All links were isolated for " & selectedDoc.Name
End Sub
I'm interested in learning how to effectively identify and isolate various link types within a part or product using VBA. Any code examples or suggestions would be greatly appreciated.
Thank you for your assistance!
Basically you want to remove all links as if you run Edit-Links command? Not possible with VBA.
