Cutpoint Minimum thickness of Closure weld
Strell
1
Hi all,
Is cutpoint minimum thickness required for new to new closure weld joint as per API 570? On what basis it is calculating??
A meaningful Subject that can be searched is required. Report to Admin and have them modify the subject to your choice.
Good Luck,
Latexman
Strell,
I can see you're new here but seriously, look at what you've written and ask yourself who, apart from you, would have any idea what you're talking about?
No section number, no drawing, no sketch, no background information on you or your role or the issue at hand.
People here are helpful, but only when given something to work with.
