DrainageEnthusiast
- Mar 5, 2011
- 11
If the existing or proposed channel I'm modeling (with steady flow condition) has a mix of mild and steep ground slopes, which flow regime shall I use in order to predict the possible water depths along the channel?
Subcritical
Supercritical
Mixed
I tried to compare the output results of each but it seems very little difference.
Subcritical
Supercritical
Mixed
