Intralink 9 - add new parameter to search criteria
blantek212
Computer
Oct 3, 2010
8
I need help adding a parameter to the search criteria in Intralink 9. I need to find all parts that have the bending table set to "ROUND." I found the parameter responsible for this, which is SHTMTL_BENDTAB, but I can't select it in the search criteria. Do you have any idea how to add SHTMTL_BENDTAB to the search list?
I think this has to be part of the Intralink configuration to add it to the database. You need an administrator for Intralink to do this.
