wsmith22
- Nov 9, 2005
- 61
I am reviewing NACE MR0103-2015. 13.1.1 specifies the heat treatment conditions of carbon steel materials. Can someone verify my assumptions are correct or point me to a website or document that can verify these assumptions? Searching the forum and other websites, I assume the following:
SA-105 materials (flanges and fittings) need to be normalized. As-forged does not meet the heat treatment condition
SA-516 Gr.70 plate is acceptable. We have had customers specify normalized in the past but that is a user requirement
SA-106 Gr.B pipe that is hot finished meets the requirements of the hot rolled condition. (per A Compendium of Inquiries and Interpretations for NACE MR0175/ISO 15156)
SA-36 will need to be ordered normalized
I'm not sure about SA-53 Gr,B ERW due to the seam weld. May be an issue with the HAZ?
SA-234 WPB butt weld elbows and pipe caps? Assume normalizing is required.
Is there a document similar to "A Compendium of Inquiries and Interpretations for NACE MR0175/ISO 15156" for NACE MR0103?
