4lpaca
- Aug 14, 2024
- 1
PV Elite calculation report stated that "The CG is computed from the first Element From Node". So, where is this center of gravity actually measured from? Let say, the report stated that "Vessel CG in the Fabricated (Shop/Empty) Condition is at 2500 mm. Is 2500 mm CG location measured from datum or from the very first node? I just want to make sure because I can't really find anything on PV Elite help.
Thank you in advance!
