NX Assembly Part Family
s_hightower
21
Hello, I'm working in an assembly part family and I'm trying to select different components in the component window, but I'm not finding them in this window. I can see them in the Assembly Navigator, but they aren't in the Component window. How can I add them to this window? (There are components in the original window, but I just cut them out for display.)
Hi, when I try to do this, all top level components (parts or assemblies) that are visable in the Assembly Navigator show up in this display window. Are you use you are not looking for components that are inside an assembly? Then you can't find them.
Werner
