Galvanic corrosion of similar-ish steels
just_some_shmuck
We all know different metals can cause galvanic corrosion, but can you get galvanic corrosion on similar-ish steel alloys?
For example, could 4140 and 1026 cause problems if they are in long-term contact?
You are more likely to have galvanic issues just because of variations in surface condition on the same material.
Don't worry about this.
I have found that the strength of the steel correlates to its sensitivity to galvanic corrosive. For example, 70ksi welds or 150ksi bolts tend to be anodic to A36 steel structures.
In open air you won't notice much but submerged in salt water there will be substantial galvanic corrosion effect.
My understanding is that molecules of the different alloys within the metal itself can form galvanic cells if exposed to electrolyte.
This is true for brass. In the case of brass it's called dezincification. I don't know of any other examples.
Some types of cast iron are very subject to graphitic corrosion/ graphitization, a similar degradation mechanism to dezincification of brass.
