ONENGINEER
Geotechnical
- Oct 13, 2011
- 284
Hi, I have three 250ft boreholes with only SPTs every 5ft for a heavy foundation of 1000 m2. The soils are predominantly silt, some clayey silt and (silty) sand in a till context. The silts to me err on the sand type rather than clay. I will have some Atterberg limit tests to verify.
Grain size distribution (GSD), PI and moisture content (mc) tests have come in my mind. My challenge is how many of GSD tests they should carry out to avoid ending up with an excessive number of lab testing, assuming the overall soil types are not much different.
I understand the importance of moisture content tests for silt/clay when compared to PL. However, for sand type soils (all below water table) I am not sure how the moisture test results are utilized in design if i decide not do do these tests. Similar boreholes by others got 50-100 moisture content tests and no indications in their geotechnical report if the mc results were actually used.
In other words is there a minimum GSD and mc test numbers below which the investigation could look insufficient. Thank you.
