edison123
- Oct 23, 2002
- 4,460
5100 RPM (85 Hz) GT driving a 3000 RPM (50 Hz) generator via a gear box is showing high vertical vibrations during startup (after a year-long shutdown) in GT front bearing (NDE) as below. GT rear bearing (DE) also showing similar high vibrations.
Both GT and generator white metal bearings are new ones supplied by OEM.
Overall GT vibrations increasing from 5 mm/sec to 20 mm/sec within 10 minutes at rated speed of 5100 RPM.
Generator excited to rated 10.5 KV but not synched (due to high GT vibrations). Generator vibrations are stable at less than 1.0 mm/sec from unexcited to excited.
Vibration probes are mounted on the bearing housing tops at 90 deg for both GT and generator.
Any idea why GT vertical 1X (85 Hz) is so high?
GT NDE Vertical
GT NDE Horizontal
GT NDE Axial
Muthu
GT NDE Vertical
GT NDE Horizontal
GT NDE Axial
Muthu
