For a walk out basement in a climate where the frost line is only 12", how do you all normally detail the foundations? I prefer to have footings and walls on all four sides of the house, including the walk out side. This allows me to completely isolate the slab on grade which is the best way to prevent cracking.
However, most contractors in my area insist on only pouring footings and walls on three sides and pouring a turn-down slab on the walk out side. The contractors claim my way is more expensive, but, if you draw both to scale and you design the turn-down correctly (even just using the minimum as shown in the IRC), my way has almost the exact same concrete area. I also see a turn-down footing being more work as it creates a weird detail where the wall footings transition to turn-down footings. Additionally, it ties the slab to the already poured wall footings.
How does everyone else detail this? Attached are details for a turn-down (which I don't use for walk out basements) and a sub-wall (which I do use for walk out basements). Note that these are only sketches.
