ETABS Wall Modelling for ASCE 41-17 Plastic Hinge Assignment
Rendradi
4
Modelling ASCE 41-17 based nonlinear moment frame structure incorporating 5 meter wide shear wall in ETABS, but shear wall plastic hinge only available in frame assignment. Do I need to model the wall as frame? If so, should I use single wide column or multiple slender column?
Yellow is shear and core wall
