Fatigue analysis screening criteria - Method B (ASME VIII-II $ 5.5.2.4) 1
Cathie16
Materials
Mar 30, 2023
11
Hello all,
In ASME fatigue screening methods, could someone please explain how to find the N[(KfbHc(3S))/2] in the eq. 5.19 ? Does it corresponds to N at [(KfbHc(3S))/2 ] in SN curve of the selected material?
Similarly for eq.5.20, whether ΔPN = 2PSas/[KfbHc(3S) ? or if ΔPN is the maximum range of pressure fluctuation during normal operation, excluding startups and shutdowns (input to be given by client) then NΔP is the corresponding number of significant cycles ?
This part is bit confusing and will appreciate really any suggestions on this?
Thanks in advance
As said in the last sentence of Step 1.:
ASME Section VIII said:
Note, in eqs. (5.19) through (5.24), the number of cycles from the applicable design fatigue curve (see Annex 3-F) evaluated at a stress amplitude of s[sub]e[/sub] is defined as N(S[sub]e[/sub]).
Regarding your second question - the answer is yes.
Is that clear now?
