Ohuti
- Sep 12, 2024
- 3
I'm reaching out for assistance with an energy-saving project I've been tasked with. Our industrial process uses a furnace to heat thermal oil, and we're currently producing more heat than required. To optimize energy consumption, I need to calculate the potential for lowering the setpoint temperature of the thermal oil.
Can anyone help me with the following:
1. What calculations should I perform to determine the feasible temperature reduction?
2. What factors should I consider when evaluating the impact of a lower setpoint temperature on our process?
3. Are there any specific energy-saving opportunities I should investigate in this context?
Your guidance and expertise would be greatly appreciated. Thank you in advance for your help!. I have made calculations. I will upload the file thank you.
