edwardmp2009
Chemical
- Dec 15, 2011
- 16
I recently purchased a plate heat exchanger for our process which should cool down a gas stream from about 850 deg C to 50 deg C using water coolant. The heat exchanger supplier provided the heat exchanger which he insisted could handle gas temperatures close to 850 deg C as long as there is adequate water flow to avoid overheating the plate material and also making sure that the water coolant does not boil. The nameplate on this heat exchanger is as shown in the attached image in which I have hidden certain information for confidentiality purposes.
I got confused after seeing that the allowable temperature (TS) is specified as -160 to 190 deg C since I interpreted this as fluid temperature. Upon seeking clarification from the supplier, they said it was plate temperature. May you please clarify if the temperature (TS) specified on the name plate is plate temperature or fluid temperature? I have done some internet research and saw that many heat exchanger suppliers never specify whether this refers to plate temperature or fluid temperature but use the following terminology:
TS - maximum allowable temperature
PS - maximum allowable pressure
PT - test pressure
VL - chamber volume.
Thank you in advance!!!
PT - test pressure
