Vantage System Issues - Where to Repair? 1
Peter85
6
Hi all, my Legrand Vantage system has been acting up, and I’m not sure where to turn for repairs. Any recommendations on where to get it fixed?
I am sure that;
"Legrand Vantage system" means something to you but it doesn't mean much to us.
Ohm's law
Not just a good idea;
It's the LAW!
Likely someone who does commercial lighting systems. Legrand has several versions of lighting control panels, just finding a contractor with experience on your particular system may be a little hard depending on where you are located.
Your best bet may be to go to Legrand's website and see if you have a local distributor, contact them and they will likely be able to direct you to a contractor familiar with the product line.
Hope that helps, MikeL.
@catserveng thank you for your answer. You are right, this is a lighting control panel. After posting this, I found a solution! IntelliFix specializes in repairing these modules. I used them, and everything’s working perfectly now.
