mahara7a
- Jan 14, 2020
- 16
Hi guys. I have a situation where conduit be connected using flexible conduit mid-length of the conduit. In my case here, the flexible conduit is connecting the conduit embedded in slab with the conduit embedded in brick wall (highlighted in yellow refer pic).
My questions are:
1) Is this allowable as I cant find any restriction in IEC Standard?
2) Can flexible conduit be used when punching through brick wall (Conduit between rooms)?
Thanks.
My questions are:
Thanks.
