what is the best required load chan
Osama Abdel Latif
1
what is the best required load change which will not impact the Francis turbine?
Osama,
I can see this is your first post, but are you serious here?
You provide absolutely zero engineering data here and actually expect a sensible answer from anyone?
"Best" is a highly variable term in any case, and "not impact" is also very vague.
From that question my answer would be that the best required is no load change at all.
