Mindaugas_Kukis
- Sep 12, 2023
- 6
Hello, Experts,
I have question regarding external rafters for rafter supported cone roof. Had a project where stainless steel tank was designed but they wanted, for price cause - to do external rafters from carbon steel. When the rafters are inside, the end in shell side I make UPN beam inside with plates around the shell to fix rafter ends and in the middle of the cone - construction from plates and profiles similar as shell side with plates.
Searched the internet about solutions for rafters fixing from the outside in ends (shell side, cone center)- can't find any examples. Could you share some? As I've seen it's good as well for tank roofs with internal coating to have rafters from outside. In these cases tanks are insulated, the ones I investigate, so no problems with water accumulation on roof.
