EVALUATED CORROSION FOR STRUCTURE OF MAST/DERRICK IN OIL INDUSTRIES
C4M1L0
1
As we know the allowable thicknesses in a structure corresponding to a derrick mast corresponds to 10% of its nominal thickness according to API RP 4G, however, how would this corrosion be evaluated in the case that in the same structure there is a hole for a pin.
