es335
- Sep 17, 2002
- 32
When calculating the pressure drop of a manifold using standard minor loss coefficients found in an everyday fluid mechanics book, it goes without saying that the calculated pressure drop will be an estimate only (due to the inconsistencies between the actual design and the “standard” loss coefficients). But to what degree can one expect the calculation to mach a measurement? The local turns and bends can be approximated and similar features can be found in the collections of loss coefficients, but differences will remain, on large and on small scale.
Is it possible to say something about the magnitude of the error introduced in the calculation? Is the difference between the calculation and the measurement expected to be around 10%, 50%, 100% or ???
I know that it depends on the actual design, and my design is complex, but as I said above, most of the local features are common (bends, turns, splits, etc.).
Christian
Christian
