TJT
Mining
- Apr 11, 2002
- 19
I need to increase the range of a couple of flow meters because of re-sized pump impellers. I need to know how to calculate the new DP. Is it just a ratio of the new range vs the old range x the old DP? Since it is not going to be a significant increase in flow range I will use the existing transmitter and orifice plate.
Thanks...Tim
Thanks...Tim
