aatara
Nuclear
- Nov 4, 2002
- 20
Hello, I have a 316 SS 30" (Schedule XS) pipe after a multiorifice plate in a water cooling systems of a power plant. I have signs of cavitations (sounds). I´d like know the problems associated and the erosion-corrosion rate.
Should I test the pipe unde UT to determine the evolution of the wall thickness?
Thanks in advance
Thanks in advance
