sayee1
Materials
- Feb 6, 2003
- 281
When welding the piles offshore one of the main criteria is the welding productivity. To decrease the time of welding(Horizontal position with 15 Deg bevel on lower tubular and 30 Degree Bevel on the upper tubular), upto 6.3mm electrodes are used effectively. Now, I have seen welders doing it in other positions and would like to know the nuances and precautions as well as the adv/disadv of using what some people call "slag welding". What it means is that for each layer, no cleaning of the slag is done in between runs . But by the welders' skill the slag is broken down and the turbulence of the weld metal and the arc force bring the slag back to the top(The slag cannot be remelted by the welding arc). Then after the completeion of each layer, the slag is wire brushed. What this would mean is that the cleaning time after every run can be avoided and cleaning time thus minimized. Anyone having any feedback/experience/comments please?
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
End of all knowledge is the attainment of immortality!
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
