altor
- May 14, 2003
- 6
Hi. I'm new to the list so I apologize for not knowing accepted process. I hired a contractor that built a footing for a retaining wall that blocked some natural drainage in an city easement. In times of rain or when the adjacent neighbor waters property, the run-off accumulates and will not disperse naturally. The footing cannot be removed nor can the grade be changed to re-establish flow. Are there alternatives like pumping systems to removed the water? I've thought of a sump pump but this is in an area where soil will likely contaminate the mechanism, which would imply there is a reliability concern. Thanks for your help in advance.
