ick2
- May 16, 2003
- 41
I am dealing with a foundation wall around a sidewalk vault. The wall is made out of stone and is 48' long and 9'tall (grade to underside of sidewalk beams). A 20' wide section is leaning 1 or 2 inches towards the vault. We need to support this wall. The owner wants a cheap solution. All the work will be carried out from below (the basement) so as not to disturb the sidewalk above. Any good ideas???
thank you
thank you
