roca
- Aug 21, 2002
- 276
We have a vessel designed and fabricated in accordance with ASME VIII Div.1
The vessel material is A516-Gr.70 + SS 316L cladding and the vessel has been PWHT.
It has now been found at site that there are some problems with the cladding before the vessel has even been in service.
The cladding in certain areas will need to be stripped to the base material and weld overlay applied in its place.
We are intending using minimum amperage parameters for the WPS with increased travel speed to minimise heat input to <0.77 - 0.81kj/mm.
My question is will PWHT nedd to be re-applied?
