v2
- Jun 2, 2002
- 95
#1. is it a good idea to build a two story house with CMU walls and wood 2nd floor and roof trusses on a wall footings that are cast monolythicly with the 4" concrete slab on grade? ( similar to a thickened slab and/or edge )
or
#2. is it better to use the other option which is to cast wall footings first start the stem walls and then cast the slab on grade with premolded joint filler material all around?
please state why you would go with either one of the above options.
Your thoughts are appreciated.
V2
