khshah
- Sep 2, 2002
- 8
We need to do Load Rating for H-20 load for Cast-in-Place Post tensioned box Girder two-span continuous bridge. We have software called "WINBDS" that performs load rating check for only flexural load. I will appreciate if any of you could let me know if you have used software that performs Load Rating check for the Shear Load. Thanks a lot.
