Valve : predict fuel losses with water test results
kerozene
New member
CA
Hi!
I need help to convert hydraulic loss results obtained with a test with water into predictions for fuel. Note: flow is laminar (very slow).
Here's what I have in mind, please tell me if its correct. (please do not reply if you're not sure...)
0- I have test results with water were I have losses (inches of H20) for multiple flow points.
1- Calculate the K factor with the losses measured with water.
2- Plot the K factor vs. the Reynolds number (with water tests). (Which gives me a nice y=C*x^(-something) curve)
3- For fuel prediction, create flow points (2 GPH, 4 GPH, 6 GPH etc...
4- Calculate the Reynold number for the fuel points.
5- Use the appropriate K for the Re number obtained with the water tests.
6- Calculate the losses for the fuel flow points with the K.
Is this procedure ok?
If not, what would you suggest?
Thanks for your time,
Alexandre Lamoureux
Flight Dynamics Corporation
