Badplaid
Materials
- Apr 8, 2003
- 4
A customer of ours is carburizing 5120 (C-0.17-0.23, Mn-0.60-0.90, Cr-0.70-0.90) steel plate 3/8" thickness to a 60-62 Rc. That grade, in the volumes they need, does not exist domestically....they would need to buy a year's worth for one mill run.
I thought of the possibility of subsitituting a A514 Grade B chemistry (very common grade and easy to get...and much cheaper) in the non-heat treated form as a replacement, which they can then case harden after forming and welding:
A514 Grade B
C-0.12-0.21
Mn-0.70-1.00
Cr-0.40-0.65
Mo-0.15-0.25
V-0.03-0.08
Ti-0.01-0.03
B-0.0005-0.005
What problems or pitfalls might be expected? How much of their process will have to change? Is this a good idea? Metallurgically, I dont see much of an issue, however, I am not a heat treater and could be missing something.
Any help is appreciated.
Alex
A514 Grade B
C-0.12-0.21
Mn-0.70-1.00
Cr-0.40-0.65
Mo-0.15-0.25
V-0.03-0.08
Ti-0.01-0.03
B-0.0005-0.005
Alex
