high pressure pneumatic regulator 1
cbert
22
Can anyone supply some leads for suppliers of high-pressure pneumatic regulators? Spec info: Inlet press.= 3000 psi, Outlet=175 psi, Cv= 0.2, media is nitrogen.
I am really impressed with the responses. This is my first experience with eng-tips and it has been very helpful! Thanks to all!!
I just received a weight limitation constraint of 0.33 lbs.
That knocks out units from Fisher and Hale Hamilton. Any other possibilities without having to go custom?? Thanks!
I assume that your application is military or aerospace?
If so I assume you have volume limitation too, therefore you will have to go custom.
I have the experience and the knowledge to help you.
I just requisitioned four of that very regulator description except using fuel gas. The manufacturer for many analyzer applications. Check GO Regulators, I bought the PR-1 series in 316L Stainless Steel with 1/4-inch connections. You have several seat choices and can select self relieving or other diaphragm options.
John
