stanking
- Jun 24, 2003
- 6
These 3 inch pipes (not insulated) supply hot oil to each press platten. oil temp is 410 deg F. These secondary loops have constant oil circulation. If sprayed with fire hose (2 inch) with ambient temp water is there any chance of pipe warpage? This press has 16 plattens 8 ft by 16 ft and warpage could result in mechanical interference between hot oil supply pipes as press is opened and closed.
Thanks, Stan
Thanks, Stan
