tw
- May 30, 2001
- 70
We have a 10 story office building, steel frame with composite deck/beams, laterally braced in core area.
Architect has asked that we put columns along building exterior outside of floor slab, so their exterior wall would run uninteruppted. In other words, steel girder would extend outside of slab edge by about a foot into web of wide flange (which will be inside the cavity of a precast column wrap).
The building is laterally braced in both directions in core area. The exterior columns in question would be up to 8 stories.
Obviously, these columns would be braced in one direction at each floor by girder framing into it. Less obvious is if this would be sufficient to brace column in other direction (strong axis).
Opinions?
Opinions?
