rlewistx
- Jun 21, 2003
- 98
I have a question about using COM624 with seismic loads.
There is an option for the loading to be "cyclical". I assume this is what I want for seismic loading. Is this a correct assumption?
If I check 'Y' then I am asked how many cycles? What would be an appropriate number?
Next question has to do with the soil modulus 'k'. Should this value be adjusted for seismic loading?
Then I have a question about the p-y curves. If the program is doing cyclic loading does it adjust the p-y curves accordingly. In some literature I read it tends to indicate it does.
Thanks.
Thanks.
