stanier
- May 20, 2001
- 2,442
I am seeking more knowledge of the behaviour of rubber ring jointed pipes in weak soils. If the soil is weak and thrust blocks are to be avoided thrust restraint fittings can be used at changes of direction. I would like to know of a procedure to calculate how far back from the bend can RRJ fittings rather than restraint type fittings be used.
WHat aprameters of the soil do I need and how do I go about specifying them so that the geotechnical engineers or soils scientist comes up with the right data.
Please no lectures on I should be using PE or other integrated pipe materials.
Sharing knowledge is a way to immortality
