Sparweb
Aerospace
- May 21, 2003
- 5,133
Trouble with Bruhn, A17:
I'm trying to find stress in skin due to pressurization. I'm using Section A17.7 of Bruhn, because it combines plate and membrane analyses. (I've already tried analyzing the membrane stresses, this section looks more realistic). The coefficient given as
(q/E) * (a/t)4
is used in the table, and given for typical values of 12.5 to 250. When I try to calculate the coefficient using the data I have:
pressure = 5 psi
a = 8 inches
E = 10.7 E6 psi
t = 0.032 in
The resulting coefficient is an order of magnitude greater than the values in the table.
What could I be doing wrong?
STF
(q/E) * (a/t)4
pressure = 5 psi
a = 8 inches
E = 10.7 E6 psi
t = 0.032 in
STF
