scheckie
Computer
- Jun 27, 2003
- 2
Does anyone have suggestions for what metal to use for the frame and suspension of an ATV I am designing and building soon? I need something light and strong but also easy to work with and weld? It should be able to take 15ft. jumps and various terrains. I would like the target weight to be around 600lbs for the vehicle. If you could make a dream ATV,what metal would you use?
Thanks a bunch-
Thanks a bunch-
