EBF
- Jun 2, 2003
- 62
I am working on a project in which our specs call for minimum compressive strength of 2500psi for lightmweight CMU blocks (85-105pcf). I got an RFI from the contractor saying that high strength blocks (i.e. 2500psi) are medium weight. I was under the impression that we sould specify both lightweight and higher strength, is this correct? What problems could result from our specs?
