Solidworks Photoworks addin
Neilt
1
I Have just installed Solidworks 2000 and keep getting an error message about a data directory that contains the photoworks sample images, also when I run photoworks within Solidworks there appear to be no materials. Does anyone know how I can get photoworks to work.
There is a file you need, I believe it's "lworks". That will get you the materials and take out the error. I don't have the file but check your SW CD.
Hope that helps,
Scott Baugh, CSWP
Can sonebody post this file? Seems that I get the same error message.
