During the precipitation headening process of 17-4 PH stainless steel a light heat tint (oxide film) on the surface is created. Normally, we require the heat tint to be removed either by mechanical means such as wet grit blasting, or by chemical means such as light pickling for several minutes in 10% nitric 2% hydrofluoric acid *by volume) solution at 110-140 F. However, I have been told that precipitation hardening in a vacuum eliminates the heat tint (oxide film) created during the hardening process.
